Sram Force 22 Crank weight
Schnavel
I'm trying to establish the weight difference between a crankset from sram force 22 and the new sram red crankset, with particular reference to the drive side crank arm and spider.
I'm looking at the BB30 version of both cranks, 172.5mm with a spider for 53/39.
I know the sram red drive side (arm, spider and rings), weighs 361g - what does the sram force 22 combination weigh?
Thanks Bertus,
But those are the weights for the entire cranks.
I'm looking specifically at the weight difference between the force and red chain rings - I'm guessing the force version is heavier?
Also, force uses a longer axle, so it will weigh more. Ideally I'm wanting to know the weight of the sram force 22 drive side arm and spider - I plan on mounting red chain rings
