Goodwood Cycle Route Advice
SLINX
Howzit guys if i wanted to cycle from Goodwood down to Marine Dr, would I be able to turn into Container Rd and then follow along Duncan road in the harbour area to pop out at the V&A. The reason for wanting to take it is because it seems a bit safer than other options to get from Goodwood to Town. Essentially the question is - are you allowed to cycle down Duncan road?
The short answer is no. Unless you have a permit, the Port Authority will not let you onto the access road. Plus I doubt the trucks there have much care for cyclists, squish factor possible
