Stages Power Reading
Patchelicious
Mine did the same once when I used Stages.
I did a Hard reset on mine and all was fixed.
To perform a hard reset on the unit.
Remove battery and touch the side of the battery to the two contacts, one being on the side of the battery compartment and the second being the brass circular piece that sits under the battery
After performing one of these actions and re-installing a good battery, attempt connection again through your head unit or the StagesPower app. If you are able to connect to the StagesPower app, please stay connected long enough to check for a firmware update. If one is available, it will notify you within the app to update the power meter.
