Trainer Road erratic power readings
So i recently upgraded my Garmin 500 to the Garmin 520. I use the speed and cadence sensors on my IDT linked to Trainer Road app. Ever since using the 520 speed sensor on the rear hub, i'm getting very erratic power readings on the TR app - I'm using an older TACX Flow trainer - so i'm training with virtual power and not smart trainer.
With the older magnet speed / cadence sensor from the 500 the power readings were fairly smooth.
I emailed TR and tried all their remedies
Tyre Pressure - check
re-calibrate the trainer - check
increase pressure of wheel on the trainer roller - check
mounted the sensor backwards / forwards on the hub - even mounted it on the spokes
Nothing works ?
Anyone else experience this ? Is there a fix ?
Why not revert back to the old sensors? IIRC, they will work with the 520
That would be a solution, but wanting to sell the 500 as complete, maybe reduce the price and sell it without
