Scott Spark RC 900 WC Front Hub Torque Cap Conversion
Ingo
Guys,
Is the Scott Spark WC front hub a DT Swiss 240 hub? The reason I ask is that the DT Swiss original caps look slightly different to what my bike has.
DT Swiss 240s Torque Caps
dt-swiss-torque-cap-end-caps-black-for-2
and my current Scott front hub caps look like this
dt-swiss-15mm-t-a-conversion-kit-front-1
Ignoring the fact that the top one has larger diameter to fit the fork, the concern I have is the original Scott has two retainer rings to keep the cup in place and the DT Swiss 240s does not but it has a slot on the inside.
Could it be that the Scott hub uses the 350 torque caps?
dt-swiss-torque-cap-end-caps-black-for-3
I need to be sure as I have a brand new set of 240s caps in the garage.
Thanks,
Ingo
That is the standard end cap, I need the torque cap size one.
BUT, your suggestion had 350 in the description leading me to believe that it's indeed a 350 hub and that this one will work?
