brake hose advice
dewaldsss
Hi Guys
I need some help on Shimano disc brake hoses
Need to change the hose on my m9000 xtr and from what I understand I need to use sm-bh90-sbm
I can only find sm-bh90-sb availabe online but from what I can see the M is for magnesium calipers thus the threads on the banjo bolt is different as per image below
Surely the old banjo bolt can be reused?
You can re use the banjo no problem. Just replace the o-rings.
The correct banjo for the m9000 brakes is part number Y8JA09000
But for reference. The left hand bolt is for the m9000 calipers as they are magnesium. The right bolt is for the xt/SLx calipers
What are you paying for your line?
