2018 Fox 36 Factory RC2 Volume spacers
CdT85
Hi Guys and Girls,
I need some assistance regarding volume spacers for my 2018 Fox 36 Factory RC2.
I received some fox 34 volume spacers (PN 234-04-953) from a friend, and according to the online manual they can be used in the 36 Speed -Ped-elec version of the forks. The Float spacers are PN 234-04-736 (I attached a screenshot of the manual)
What is the main difference between the green and orange volume spacers? Both is 10cc per spacer? And will the Green one work in my 36?
Thanx in advance
The 36 ebike fork stanchion has the same internal bore diameter as the standard 34, and uses the same air spring and topcap - which is why the 34 volume spacers fit. You may be able to use the 34 spacers in a standard 36, but they'll probably rattle.
At R 100 odd a spacer in a R 20k fork I'd rather just use the right thing for the job.
