Diamondback DB4L Dual Sus
Nartjie
Hi There guys...
can anyone tell me if they are familiar with the Diamondback DB4L dual susp mtb??
I'm looking at getting it for my kid and want to find out if it's any good or not etc
I don't know that specific model but DiamondBack is a good brand that has been around for ages. Do you have more info on the particular bike? 2nd hand or new? Price and spec?
Thanks LWB....
Not really now.
Friend of mine maybe wants to give it to me for free....never say no for a gift.
She said it was an expensive bike, not sure, her husband passed and its standing there in the garage.
So yes, I will take it, just wasn't sure about the make etc.
Will go and check it out more and inform you
Greetings
Best Use
Mountain Biking
Frame
6061 aluminum
Bike Suspension
Full Suspension
Fork
RockShox Recon Silver, 130mm travel with 15mm thru-axle
Rear Shock
RockShox Monarch RL
Crankset
Shimano Deore, 38/24
Bottom Bracket
Shimano
Shifters
Shimano Deore
Front Derailleur
Shimano Deore
Rear Derailleur
Shimano Deore
Rear Cogs
Shimano HG50, 11-36, 10-speed
Number of Gears
20 gear(s)
Brakes
Shimano M355 hydraulic disc
Brake Levers
Shimano M355
Rims
DB SL7
Front Hub
DB SL7, 32h with 15mm thru-axle
Rear Hub
DB SL7, 32h
Wheel Size
29 inches
Tires
Schwalbe Rapid Rob, 29 x 2.25
Handlebar Shape
Riser Bar
Handlebar
DB SL318b
Stem
DB aluminum
Seat Post
DB SL309p alloy micro adjust
Saddle
DB Race
Pedals
DB aluminum platform
Headset
Zero Stack Ahead 1 1/8
Chain
KMC X10
Weight
33 pounds
Bike Weight
Bike weight is based on median size, as sold, or the average of two median sizes.
Gender
Unisex
Diamondback make some very good bikes, however, the only ones that we see in SA are the cheap and nasty ones that you get at Makro.
It's possible that this one is a special import and is one of the better ones, however, considering that they are prepared to give it to you, I'm thinking that it is one of the cheaper ones. (for a non-cyclist, R2 000 is considered expensive).
But hey, as you said, it is for free, so take it.
I only saw your post of the specs after I posted the above. The specs look pretty decent and it is definately better than what you get at Makro.
Best Use
Mountain Biking
Frame
6061 aluminum
Bike Suspension
Full Suspension
Fork
Rear Shock
RockShox Monarch RL
Crankset
Bottom Bracket
Shimano
Shifters
Shimano Deore
Front Derailleur
Shimano Deore
Rear Derailleur
Shimano Deore
Rear Cogs
Number of Gears
20 gear(s)
Brakes
Brake Levers
Shimano M355
Rims
DB SL7
Front Hub
Rear Hub
DB SL7, 32h
Wheel Size
29 inches
Tires
Handlebar Shape
Riser Bar
Handlebar
DB SL318b
Stem
DB aluminum
Seat Post
Saddle
DB Race
Pedals
Headset
Chain
KMC X10
Weight
33 pounds
Bike Weight
Gender
Unisex
You getting that for free, TAKE IT!!!!!!!
Hi guys, thanks for the replies.
Guess what?!
I TOOK IT
Will check it out over the weekend and see what needs attention.
All the best and safe cycling
