BB386 in a BSA Frame
Kalahari Vegmot
I'd like to fit a FSA BB386 crankset in my standard BSA 68mm road frame.
I can't seem to find the FSA adapter locally.
Will this e*13 adapter work? https://www.evobikes.co.za/components/bottom-brackets/e-thirteen-bsa-68-73mm-threaded-bottom-bracket.html
Would I need a wavy washer or something as well? It says "Spindle spacers and wave washer are not included and are superseded by the APS adjuster". I don't see an "APS adjuster" on the picture though. Am I missing something?
  On 3/15/2020 at 4:22 PM, boosted gp said:
Or you could go to positivesportssolutions.co.za for 1/4 the price.
Baaaaaa :(
Where were you two days ago!?
I ended up getting a FSA ceramic BB386BSA as that's all that CRC had.....
Oh well I guess it's 2 grams lighter than the Token one, so, you know, speeeeeeed :ph34r:
Whichever model of BB you purchase, ensure that it has good quality 6806 RS bearings.
SKF
NTN
FAG
I'm not a fan of overpriced enduro bearings nor do I buy into the "Designed for bicycles" tag line.
Token design concept is good but the bearings are pretty cheap and don't last. I've fitted SKF to mine and all good for the last 6months
SKF
NTN
FAG
Thanks. I got the genuine FSA one, which I'd hope is good quality, at least at the price they charge...
Found this video as well which I found quite insightful:
https://youtu.be/o7iZVfSDbiA
