Rockshox sid fork oil
WDL
15wt fork oil should be fine but make sure to change it at 50h intervals, otherwise Magnatec 5W30 if you can get it.
5W fork oil will feel horrible and will probably wear out stanchions and bushings pretty quickly.
What 15wt do you have?
Hi
Where are you located?
Apparently Magnatech 5W30 can also work.
Drop Stoke a PM, Andrew can usually give some advice.
Hi
Thank you gents,
I'm in Marble Hall, can get the 15wt from a friend. Will find out what 15wt it is.
Thank you gents,
