Power2Max NG ECO chainring setup
snutkin@gmail.com
Hi guys,
I just want to check something.
SRAM GX, 3mm offset factory chainring.
Bike is boost.
I have fitted an NG Eco and am now fitting the chainring.
Do I need spacers or does fitting the chainring directly to the power meter allow for the standard 3 mm offset? My understanding is that you only need to use spacers when using this set up on a non-boost bike. Is that correct?
Thanks in advance!
Hi guys,
Bike is boost.
Thanks in advance!
Fit the chainring straight onto the PM. If the bike was non-boost you’ll put a spacer in between the chainring and the PM.
That then confirms that what I have done is right. Thank you very much.
