I'm looking to buy a fluid trainer.
What's the difference between the Fluid and Fluid 2 Saris (Cycleops) trainers?
Google doesn't help much.
And where can I buy one in Cape Town area?
As a Fluid2 owner just be aware of its limitations regarding Virtual Power. Google "fluid trainer thermal drift" and you'll quickly find what I'm talking about.
If you aren't planning on using it in conjunction with a speed and cadence sensor for Zwift/Rouvy/Trainerroad etc. then the Fluid2 is a very decent trainer.
Sorry, not answering your question I know, just want to stop anyone else from getting into my predicament.
Fluid 2 is simply the newer version of the trainer. I know they adjusted the mounting mechanisms and the wheel tightening adjuster, but other than that, not sure there is much difference tbh.
I had the fluid 2 and it worked very well. As mentioned by Tyron, consider what you are wanting to use the trainer for. If it's just to spin and for warm ups, then the Fluid trainer is a fantastic, cheap and reliable unit.
