Hi all, I have an old Trek road bike with Tektro caliper style brakes. (google shows these are caliper style, not v-brake or cantilever style...???)
I want to replace the drop bars with a flat / straight mtb handlebar.
Question: Which brake levers can I use with these caliper style brakes?
(I read somewhere about long pull and short pull but still not sure. )
Links to locally available brake levers would be awesome, even 2nd hand ones.
tia
You can replace with any V Brake lever which was used on an MTB. I have some CX bike ones which i had extra but they aren't the right design. there are thousands out there as everyone rode with V Brakes for years.
Hi Paul, thanks for the answer.
These are V - brakes , right?
Read somewhere that some brake levers won't work on some brake designs.
But okay cool, I'll get my hands on a pair of V-brake levers.  :thumbup:
Yep those are V. THe other older version are cantilever but they are unusual these days -only on CX bikes You can do some googling but really what you are worried about is the cable take up rate or actuation. Older bikes were pretty much on a par. So your Shimano V Brake levers worked for road brakes. You also have single and double pull calipers but those ones are single pull. So a set of normal VBrake levers should work fine.
