Howzit guys.
I'm looking for 155mm saddle options available out there. Particularly for road setup.
I've got the Phenom on my MTB and looked at the Spez Power saddle recently.
But googling has come up quite empty with other manufacturers
I know Farr has some wide saddles, but what else is out there and i suppose, reasonably priced?
Spez has a whole range and theyre fairly priced depending on the spec... Why not just get a spez and be sure about the fit and measurement?
Leaning that way. But always open to a suggestion on something else that may be as good, if not better.
You could also look at Pro Stealth Carbon 152mm and Bontrager Montrose Pro Carbon 148mm.
Would need to be a 155. I've had a 148mm and its just too small. suffering after a couple kilos.
Saw Bontrager has an Aeolus in the right size. Will make my way to a trek agent on Monday to check it out
Nice saddle have one !
Yeah I have romins on both my road bikes... They're great, but do try get the second Evo version of them, the slimmed the nose back down. The original nose width was a bit of a ballache...
