Hi
Use to have a Powertap Joule where the backlight would come on by itself based on a sunset/sunrise time determined by gps.
Recently bought an edge 530. I see the device has a daytime/nightime mode where the background would be light in daytime and black in nightime.
My question is: does the edge have a function where the backlight would come on whenever it changes to night mode?. Auto brightness only adjusts the brightness when a button is pressed before it goes of at the set time.
The 520 switches the back light at sun rise and sun set.
Should be an option on the 530
EDIT ... did some googling .... seems the 530 went the dim/bright route as apposed to the older backlight on/off on the 520.  Lots of complaints about the dim/bright system .... lets hear if 530 owners have solved this ...
Edited by ChrisF
