Stolen: Specialized Rockhopper Pro 1X 2019
When: 20/04/2023
Where: Vredehoek, Cape Town, Western Cape
2019 Specialized rockhopper pro 1x FRAMES FRAME A1 SL Aluminum, Sport XC 29 Geometry, tapered head tube, internal cable routing, Boost QR 141x9mm forged dropouts, chainstay-mounted disc brake, replaceable alloy derailleur hanger
 SUSPENSION FORK RockShox Recon RL, Solo Air, 9x100 QR, 51mm offset, 80/90/100mm of travel
 COCKPIT HANDLEBARS Stout XC, double-butted alloy, 8-degree backsweep, 6-degree upsweep, 10mm rise, 31.8mm STEM Stout 3D-forged alloy, 31.8mm, 6-degree rise GRIPS Specialized Sip grip, half-waffle, S/M: regular thickness, L/XL: XL thickness SADDLE Henge Sport, steel rails, 143mm SEATPOST Alloy, 12mm offset, 2-bolt clamp, 30.9mm SEAT BINDER Alloy, QR clamp, 34.9mm
 BRAKES FRONT BRAKE Shimano XTR BR-M9000, hydraulic disc, 160/180mm REAR BRAKE ShimanoXTR BR-M9000, hydraulic disc, 160mm
 DRIVETRAIN SHIFT LEVERS Shimano SLX, 11-speed REAR DERAILLEUR Shimano SLX, Shadow Plus, 11-speed CASSETTE SunRace, 11-speed, 11-46t CRANKSET Stout Pro, forged alloy CHAINRINGS Alloy, 30T BOTTOM BRACKET BSA for 24mm spindle CHAIN KMC X11, 11-speed w/ Missing Link™
 WHEELS & TIRES RIMS Stout XC 29, 25mm internal width, disc-specific FRONT HUB Shimano, Center Lock™ disc, 9x100mm spacing, quick-release, 28h REAR HUB Shimano FH-MT200, 9x141mm QR, Center Lock™ disc, 32h SPOKES Stainless, 14g FRONT TIRE Ground Control Sport, 29x2.3" REAR TIRE Fast Trak Sport, 29x2.3” INNER TUBES Presta, 40mm valve The bike also had a bag touring Top Peak carrier attached to the frame.
Get further details about the incident in the Stolen Bikes section.
