Ok, here is my problem, my mavic back wheel, is making a click-click noise when i pedal, by the cassette body.
Its been to 11 different mechanics so far, problem not fixed. they say it doesn't cause problems. thats ok, but its just bloody annoying.
Does ANYONE have the answer to solve this. please help me out.Cry
mine is also doing it check the dust caps and then make sure the cones are not too tight or too loose mine have only just started but i have got this info from a very reliable source
nok ... is this under load? or just normal pedalling? is not possibly a spoke tension? is the cassette tight on the hubbody? no crack spacers? is the axle not damage? (this you could easily see on the cones if it is rubbing more on a certain spot)
nok ... this may sound weird, but what type of cranks do you use? If it is chainrings with bolts; make sure that they are as tight as can be ... KlapperKnop2008-08-03 13:33:09
ya, mt training wheels dont make the noise so crank is fine, headset is fine and so is saddle. will take them apart tonite and see if i can fine any cracks in spacers or anything like that. rim and spokes should be fine, they have all just been replaced, and the noise happened before these got replaced.
thanks turtlek, will also pull mine apart and hopefully we can sort it out.
dude before you start stripping i just had a brainwave check theat your valve extensions are secure and dont move around too freely that could be the clicking noise!!!!!!!!!!!!!!!!!
and do they also make noise on rough tar????????turtlek2008-08-03 13:56:03
i also had a noise wit my bike that sounds like it the same as yours..... it prob your skewer or your head set..... those are the most common
