For the lucky ones out there that can afford the Edge 705, I see that there is a firmware update out there. You have to make use of the Webupdater to download and install this update.
Change History
Changes made from version 2.30 to 2.40:
Fixed problem where stopping and restarting the timer could cause invalid track points.
Fixed problem where an invalid power value could be logged when stopping and restarting the timer.
Improve battery checking to remove inadvertent shutdowns.
Fixed problem where speed sensor data was not used when GPS signal was lost.
Fixed problem where low or 0 speed could be recorded prior to a turn.
steynja2008-08-24 15:40:55
