Just fitted a brand new groupset at LBS.
First, second and third rides were great.
Riding yesterday afternoon had some issues with my rear derailleur...
In the small ring in the front, no problems with shifting the rear derailleur.
If i shift to the big ring in the front, the rear derailleur "hunts", and keeps jumping between cogs, no matter what gear I'm in.
I tried adjusting the barrel, both ways, and no difference only got worse.
Before I go bug the guys at the shop, I thought I would try do it myself, any ideas?
I thought maybe the cables had stretched slightly?
check the derailer hangar as kona says and then check that the little Aluminium piece of metal with the groove is on the right way round (groove has cable in it)
Your chain might be too short..
Was thinking that, but chain is same length as before, and it would have been a problem from the start...
I'm thinking the hanger... maybe someone bumped my bike at home, and isnt owning up...!
It sounds as if your rear derailleur is changing it's alignment when going to the big chainring. It normally turns quite a number of degrees around the guide wheel axis as you are using a lot more chain on the chainring. You can spot this easily by wathcing the rear derailleur from the back of the bike on a stand and changing gears. If this is the case either the rear derailleur is bent for some reason or the hanger bracket is bent or loose as Kona has explained. Theretically the chain lead in position to the cluster block should not change when changing on the fron chainrings....
Ja, I think you guys are right...
Back to the Bike store then.
Benefit of staying so close to work, went home to have a look during lunchtime...
The rear skewers is tight
The hanger is not loose
the derailleur does not appear to be twisting
However, I did notice that the derailleur does actually jump in the smaller front ring aswell, but just not as noticible as when it is in the big front ring
THe derailer hanger could be slightly bent.  YOu will have to take it to the shop to check with a special tool.
I think you right.
I noticed pit marks on the derailleur body, like it had been hit by a stone, or gravel...
Cant figure out how though???
