I seriously doubt it. Maybe if you switch off most functions and reduce the backlight, but as far as I can remember mine lasted about 12 hours. The 705 will probably make it.
thanks
I have lost my polar cs 200, and was wondering about replacing with the 305.
Deser dash means I will be on the bike for at least 20 hours, so want something that will last that long
if you want it to last set the contrast very low turn off all alarms and backlights and then only use your functions that you will need so you will need to switch of the second bike function and all of that as well
if you worried about battery life then rather save up go for the 705 the battery life is triple that of a 305 when charged fully in the first place
