I've built a few into MTB wheels, which is quite a challenge and only works with the Mavic MTB UST rim - X8-something.
It is a fantastic hub with many benefits. Once your sprockets are worn, you turn them around and use the other side.
The double cable is a bit clunky and the reaction arm is just so much more elegant on a frame made specifically for a Speedhub.
One of the gears is particularly noisy and overall, the hub's efficiency is a bit less than a jockey system, but nothing one should worry about unless you're in the top 1% of racers and every second counts.
If I were to take a long expedition through the Andes or Himalayas, I'll fit a speedhub. Perhaps even for the Freedom Trail.
Nice and practical.
