I understand it as where the clamp is. Some clamps you can see above the pivot point and others are below. My frame can only take bottom swing but it can be fitted to both a top and bottom pull frame.
Depends on your cable routing. If it runs along the top tube and down the seat tube you need top swing. Under the bottom bracket you need conventional.
Yup! ...and the method of engagement...you can get them as follows:
Top pull bottom swing
Top pull top swing
Bottom pull bottom swing and
a bottom pull top swing
The pull part relates to where the cable engages from and the swing part relates to where the derailleur sits in comparison to the clamp!!
Top swing (can be top or bottom pull)
http://www.bikepartsplace.com/images/P/31809825.jpg
Bottom swing (ditto)
http://www.performancebike.com/product_images/250/50-6635-NCL-SIDE.jpg
Mampara2009-01-15 07:46:27
Had bottom swing on my hardtail, bought a top swing by default, it works perfectly but the bottom swing looks better...less visible on the frame, hidden behind the chainrings.
