I noticed the other day that the pistons on my (Shimano Deore) rear brake are not retracting completely. Is the fix as simply as spraying a bit of lube in there? Obviously I need to avoid lubing the braking surfaces, so can I simply remove the wheel and pads, spray, then reassemble and pump the brake?
Check' date=' there may be a small stone stuck in it[/quote']
Thanks, will look but both are sticking so I think it's probably grime.
You could also ask your LBS for a bit of mineral oil, the Shimano brake fluid.
Remove the pads then pull the brake lever to get the pistons to come out a bit more.
Grab an earbud with some meth and clean around the piston, push the pistons back and get some of the mineral oil to penetrate between the piston and the caliper.
You could also ask your LBS for a bit of mineral oil' date=' the Shimano brake fluid.
Grab an earbud with some meth and clean around the piston, push the pistons back and get some of the mineral oil to penetrate between the piston and the caliper.[/quote']
Thanks guys, gonna spend some quality time with my bike after work.
I finally got around to sorting the brakes out. Been resting a strained achilles so my bike has been rather lonely.
Just to give feedback, I got some mineral oil from my LBS and sorted it out. The pistons now retract nicely. Thanks to all who gave me input.Thumbs%20Up
Good news Kevin
What method did you use ?
I removed the pads, loosened the bolts holding the caliper onto the frame and removed the caliper to get it away from the rotor. I then applied a small amount of mineral oil around the edges of the piston and pumped the brake lever. This done, I pushed the pistons all the way back with a plastic tyre lever and reassembled.
The pistons now retract completely. The brake lever, however, seems to have more travel than the other one. Does the oil reservoir perhaps need to be topped up?
Good news Kevin What method did you use ?
I removed the pads' date=' loosened the bolts holding the caliper onto the frame and removed the caliper to get it away from the rotor. I then applied a small amount of mineral oil around the edges of the piston and pumped the brake lever. This done, I pushed the pistons all the way back with a plastic tyre lever and reassembled.
Hi Kevin
It might need a top up, how worn are the pads.
