heard yesterday that specialized will be replacing my frame and it
looks like their descion was made with my dealer before i posted my request on the hub! thanks to the guys at le peleton and thanks to my dealerSmile
harry12009-03-27 14:09:34
Why dont you go onto your other thread and make amends to the false accusation that you made due to your abuse on the frame that you cracked!!!!
dude you really need to learn how to change gears properly if your chain gets thrown off at the position tha tyour frame was cracked because not even fabian cancellara will break a frame in the spot where yours did if it was a manufacturing default!!!
so make sure that your case is rock solid before you start making false accusations against a company that had all it's bases covered!!!
ClapClapClapClap
