I am looking to replace my chain, using SRAM force.
Searching on the web, I found two variants
Sram 1070 Hollow Pin Chain 10Spd
Sram 1090 Hollow Pin Chain 10Spd
Anyone know which is the right one and what the difference is and how do figure out which one you have :)
quinton2009-04-24 09:08:05
u can use either one.
the 1090 is lighter and was made for force groupsets.
if u r not too weight conscious then th 1070 is also great. The 1090doesn't wear any quicker.so if there isn't a big price difference at your supplier then go 1090.
I will pm you prices on both to give u an idea.
