Heyall
My rear hub has a bit of play in it, and I think it's time for a replacement. Recently upgraded to Juicy 5's with 185mm rotors.
Now, i've been eyeballing the Shimano saint range, as they are apparently DH/FR specific. Only really read good reviews about this product set.
However, IIRC, the brake rotors are meant to be hub-spline mounted, and the rear mech mounted on the thru axle, ie, no longer on a drop out.
DT Swiss makes a nice6-bolt rotor to hub-mounted adapter which works very well on Shimano products.
But this is turning into a lot of extra components for what was supposed to be rear hub replacement.
So my questions to y'all are:
  1. If I take the saints, which saint components should i take to ensure compability, yet allowing me to keep my Avid Juicy 5s
  2. If I dont take the Saints, which other hub is recommended for DH?
