Hi, can anyone confirm that the SRAM X.9 Twister Shifter will work fine with the Shimano XT Rear Derailleur M771? I am looking to upgrade, and my friend said I should look into the twister. The other option would be the Shimano XT Shifter Pod 9sp M770
yup that's the one. should work fine.  I used to ride SRAM Rocket trigger shifters with a Shimano XT rapid rise deraileur and they do a great job.
Anything in the SRAM X-series requires an SRAM deraileur however (it uses a 1:2 actuation ratio - which basically means it moves the cable twice as far for each shift while Shimano equipment uses 1:1 actuation).
