i know the tubeless topic has been covered a 1000 times.
Does the Kenda S B 8 (wire bead) work well with a ghetto conversion?
Is R198 a good price for these tyres?
what expected mileage on these?
thanks
Been running Kenda SB8 (UST version) for 18 months now. No issues, nice tyre.
Rear one almost needs replacement +/- 3000km. Can probably get another 500km out of it Smile
did the conversion last night.
1st attempt with a Bmx tube (schrader valve) was  not an option, as the tyre did not seat proper at the thicker rubber around valve.
could not get a presta valve Bmx tube in PE, so used a 24" presta tube.
not ideal as you don't have a tight fit around rim.
so the conversion was done, no problems sealing and was still hard this morning
Conti2009-06-09 02:35:54
1st attempt with a Bmx tube (schrader valve) was  not an option' date=' as the tyre did not seat proper at the thicker rubber around valve.
My reason for aborting my ghetto conversion on Sunday too. My Kenda tyres (cheap ones that came with my Giant) seem to have a kink in the wire. Its not bad, but its enough for me to be cautious and rather try ghetto when I replace my tyres.
cbrunsdon2009-06-09 04:32:53
 tyre was still hard last night, so i tested my mixture to see if it will seal.
push a sewing needle into tyre, sealed straight away when i pulled it out.
as my tube do not have a removable presta core i wanted see how i was going to refill it without damaging or disturbing the ghetto conversion.
got a syringe and a piece of silicone hose at Pharmacy and it was so easy.
with a tyre level lifted tyre about 5 mm of the base of rim, not over lip
just enough to squeeze the pipe inside tyre and injected the mixture.
no waste and it sealed perfectly again.
so i dont need a removable presta core Bmx tube but just the standard Bmx presta tube.
if i can find it
