FOX Racing Shox FLOAT R with Brain Technology.
The missus's Specialized 'Brain' started to leak oil while transported (boxed by myself in a cycling box as one would for a flight) in the container. The leak continued after the bike was assembled and hanged in the store room. It now stopped - probably emptyConfused
I assume that the oil is from the 'Brain', because the Fox "Float R" is air based shock.
I will go to the dealers here, but did anyone else experienced this?
If yes, did you serviced the 'Brain' or replaced it?
ps, here some Fox service videos (I call it sideshows Wink)
http://www.foxracingshox.com/fox_tech_center/service_videos.htm
straatvark2009-06-11 10:22:52
now this is sad GBU:
You cant get new one, it is taken off, send to the UK and serviced in a pressure tank.
It would cost E300! Dead
I'm out of words.... will have to think on this one. Another reason to stick to my GT hardtail Confused
