Damaged cassette when chain at 0,75% Wear
mtbfreak
Shebeen, you're right. It is just over 1/12th of an inch, which is over spec.
Interestingly, I've been using the Google conversion feature and typed: 2mm = inches? into the Google toolbar. I took the first answer at face value without doing a sanity check. The second entry (the Jewellery store one) is of course right.
As for the paper ruler charge. I am innocent. I didn't even know they had paper rulers.
Link to comment
Share on other sites
.......I do like the way you took one of those free builder's whorehouse paper rulers' date=' but i have found them to be inaccurate before  (according to my Stanley) so be careful.
lol...well spotted...it was close enough with my stanley, and verified with my 150mm vernier caliper...
Link to comment
Mtbfreak, the key to destruction might lie in cross chaining....are you a guilty culprit?
Sounds like that is a good reason for creating those marks on the sidewall of the sprocket teeth....and not on the pressure face of the teeth (like we would expect the wear to show)...
Link to comment
JB, firstly let me acknowledge your huge experience and all your great contributions to this site.......1000%. But why so cynical of the ParkTool CC3 chain measuring device?
Surely it is just a (crdue) gadget designed to simply give Joe Home Mechanic an practical idea of the condition of his chain. I.e.: totally buggered, or still fine, or replacement coming soon. End of story. If he wants to know the exact length accurately to two decimal places, (what the hell for guys..??), get a vernier or use your measuring system.
So if the 0.75 indicator slips easily between the rollers of a (clean) chain, that's good enough for Joe Home Mechanic. He must then start the process: go buy a new chain, check his cassette, chainrings, etc.
The Parktool gadget is not meant to be a precision instrument after all. But is it really so crap that we must throw them away?
Link to comment
As I'm still new to the scene I'm doing a lot of research into chain wear and replacement. I've come to the conclusion that "ride or no-ride" tools are not perfect and more often than not criticized - just because Park Tool has one does not mean they are perfect!
The only way is a good old fashion ruler.
Personally I would take 2-3 readings on a chain and then accept the longest measurement. Even chain wear is theory, real life is a reality.
EDIT: Here is an awesome site that explains the error of measuring tools
http://pardo.net/bike/pic/fail-004/000.html
cbrunsdon2009-06-29 08:00:53
Link to comment
Ha ha ha...found this very interesting comment on that website...
What about all those fancy chain cleaners and lubricants?
There is no advantage in using these expensive products over simple solvents and lubricants; don't waste your money. If on tour, a small bottle of Phil's Tenacious Oil is convenient, though less effective than submerging the chain in oil, or using foaming chain lubricant. The various chain products do provide some level of amusement. I think my favorite is "Bike Butter."
It's easy to go into business selling chain lubricants. Just buy some small bottles and fill them from five gallon bottles of industrial lubricants. Create a fancy name, and convince bicycle shops to stock your product.
http://www.nordicgroup.us/chain/phil.jpg    http://www.nordicgroup.us/chain/flcc.jpg    http://www.nordicgroup.us/chain/fltp.jpg    http://www.nordicgroup.us/chain/fltpd.jpg    http://www.nordicgroup.us/chain/letour.jpg    http://www.nordicgroup.us/chain/synlube.gif
http://www.nordicgroup.us/chain/whitelightning.gif    http://www.nordicgroup.us/chain/t9.gif    http://www.nordicgroup.us/chain/triflow.gif    http://www.nordicgroup.us/chain/purpleextreme.gif    http://www.nordicgroup.us/chain/golden1.gif    http://www.nordicgroup.us/chain/bikebutter.jpg    http://www.nordicgroup.us/chain/prolink.jpg
Food for thought....
Link to comment
why would you use Paraffin to clean your chain???
not advisable....
Use WD40 instead LOL
Nothing wrong with using parrafin & and diesel for that matter...
Just make sure you re-lube properly after this good clean....parrafin will actually remove all the lubricant inside the rollers...that's where you want to make sure your re-lubing penetrates to after cleaning.
Link to comment
So I bought a new chain and after installation took it for a Majik ride. The chain started to skip on the first ascent' date=' and as no adjustment could be made to resolve the skipping, lead me to inspect the cluster closely. The cluster now had some nice indentations on the teeth and is basically stuffed.
Since the chain and cluster worked together don't throw them away, but continu using them together and they will give you many more miles of service.
Link to comment
