Hi guys,
I need some help here. I have a Scott Spark 30 that came with a Rock Shox Reba SL. For some reason I'm battling setting the Rebound.
This is what the manual says:"The red rebound adjuster knob for your fork is located on the bottom of the right fork leg. Turning the adjuster toward the
"rabbit" causes the fork to return to full extension faster (less rebound damping). Turning the adjuster toward the "turtle"
causes the fork to return to full extension slower (more rebound damping)."
The problem:
A brief inspection to the bottom of the right hand side leg reveals no "red rebound adjuster knob". There is only a big allen bolt which seems to be doing nothing other than screwing in or out rather loosely, which leads me to believe that it's not what I'm looking for. I'm looking at the right leg, cause there are pictures of the rabbit and the turtle?
Does anyone have pictures of what this red adjuster knob looks like?
Regards
I'm assuming here that the red knob in question is the one in the picture below...Which is not on my shock. Should I just return the bike on because of this, or is it a fixture known for getting lost?
http://bikeshop.com.ua/images/rockshox_2008_reba_sl.jpg
Cool, I found my issue. The red adjuster knob was supplied by the shop this morning. I highly suggest you pull it off and store it in your saddle bag instead. It basically clips in with minimal effort. It could easily be clipped out on a ride and lost...And this from a new shock...
Thanx for the help though.
