Worn and Smelly Helmet Pads, Halo has a solution??
Not only is the Halo designed to keep the product of your toil from running into your eyes, it also a great replacement for those worn and smelly helmet pads that you have been wanting to replace.
The Halo II acts as a filling pad, it is simple, take the old stock fit pads out of your helmet and adjust the helmet on your head as normal so that is comfortable whilst wearing the Halo, Notice something? A more secure fit than you have ever felt with the helmets stock size pads. (Halo can also be worn with stock pads in place)
Now go out for a ride, preferably on a hot day when you can really work up a good sweat. You will immediately notice that the thin Halo soaks it all up. No more showers of perspiration over your glasses!
When you?re racing downhill the Halo keeps the helmet from rocking around on your head. Unlike the helmet pads, the halo never becomes smelly and is easier to wash; you just toss it in the washing machine with your bib shorts and jerseys.
The Halo is available from www.haloheadband.co.za and cycle stores nationwide. Price Range from R150 to R250 each.
"Don't Sweat without it"
I will definitely order some, but the beanie..... EM wants the tie strap. I see there is PURPLE lubricant..... funky. Is it it good???? What is it made of???? The the Mobi Washer ..... 12v that is also good. Spare parts????? Can you adjust the spray head for a gentle spray.... looks like it on the pic.
The Purple Extreme and Golden Degreaser are awesome, i would say so cause we distribute the product. Have a look at this thread on the Purple Extreme and other hubbers comments, the Lube last for a 450 km on a road ride when applied on a clean chain, the Golden Degreaser cleans any drive train under 60 seconds cleaner than anything else on the market....https://www.bikehub.co.za/forum_posts.asp?TID=54762&KW=bike+medicine&PD=1
As for Mobi Washer, spares are available, however with less than 1% failure rate we are confidant with the product, check out these videos for info and how the Mobi Works.
