crank creaking on left side when out of saddle climbing... i have taken crank arms off, cleaned, regreased. didnt take bearing cups out, but greased them... when i put back together it creaks the same.. is my BB at the end of its life, its done +- 12000 km but never in the rain???
It's not skewers, are peddle bearings, i did check that aswell!!!
had a similar problem.
it was the 2 locking bolts on the left crank arm causing the creaking noise.
take them out and put a bit of grease on them and don't tighten to much and go for a short ride to check.
I had/have the same with my Ultegra. I have to tighten the load bolt, big one that you are supposably only do up 0.7nm, quite a bit tighter. I think this might affect the BB but atleast the sound is gone.
