Unfortunately there is no cheap way unless you find a cheap group set on the hub the reason being 10 speed chains are narrower than 9spd and therefore everything else is also different to 9sp parts
I have a Record cassette and Chorus chain that would go very nicely with that crank! Only R2k with about 500km's on them Wink
(I'm not so sure Record is the cheapest way though!) Should be able to pick up some fairly well priced parts from the cheaper ranges if you post in the wanted section, but you're going to need chain/cassette/shifters/derailleurs to change to 10 speed. (Assuming your hub is 10 speed compatible)... Remember your hub will only be shimano compatible and won't take the campy cassette without a change of body.
Dear Mr Donner
Why change to 10sp?
I run 9speed on my training rig and 10sp DA on race setup, and franky, I don't really miss that extra gear when traing (est if you're already on DA)
