Someone here might know what is causing this.
Giant Anthem, shock locked on a flat smooth garage floor.
Lift the bike slightly by the saddle and there is an audible "clunk" which you can feel as well. Sounds and feels like it is the suspension somewhere, all fasteners are tight and has started for no reason, i.e. well after any work was done on the bike.
Anyone?
Hi that clunk you're feeling is the shock reducers and the DU bushes that have worn out, your LBS should be able to sort it out, otherwise if you don't come right PM me I'll sort it for you.
It costs about R200 to do both ends of the shock...
