Any rotor will work, But I'm a firm believer that you should run Avid with avid and shimano with shimano etc...but I know that people want lighter/cheaper setups so you mix and match to suit...
All of them are interchangeable. It's a piece of steel with different patterns cut out.
The only "specs" you should be looking for is size, should be printed on the current ones or dictated by the adapters you use, and if it's Centre-lock or 6-bolt.
a rotor is a rotor is a rotor. usually, size does matter though, so does rotaion direction otherwise all compatible. BTW can't wait for my custom laser cut rotorsBig%20smileBig%20smile
