Does anyone know what is requried to mix an FSA crankset with an Ultegra 6700 components... is it all possible without any glitches or should i just stick to Ultegra 6700 chainset?
also ... is it possible to have an ultegra 6700 chainset with R/FD , 105 brakes , and 105 10spd levers?
You can run it with no hassles.    Ran a FSA crankset with Campy too, and when I get home am going to fit my new FSA crankset on my 'Dale and do it again
And Shimano is perfectly interchangeable. go for it.
sammajoor2010-01-27 02:37:20
Most cranksets are interchangable, I've run a campy crankset with Shimano as wellas a Dura ace crankset with Campy Veloce....
All Shimano is interchangable so long as you run 10sp levers with a 10sp cassette, I've also run a 9sp dura ace RD with 10sp levers and cassette.The ONLY one that will cause a hassle is the new 7900 (dura ace) levers as there is no trim on the front shifter so you HAVE to run those levers with a 7900 FD but thats the only catch...
