How shold I maintain my MTB after a particularly muddy ride?
Can i use a high pressure hose?
Are there areas i should stay away from with the hose pipe?
What should i use to degrease/clean the chain?
What lube shold i use?
Can i leave the bike out in the sun to dry?
How shold I maintain my MTB after a particularly muddy ride? buy a set of either park tool or pedro brushes.
Can i use a high pressure hose? yes you can.
Are there areas i should stay away from with the hose pipe? hubs and bb to be safe. although some hubbers says this isn't necessary.
What should i use to degrease/clean the chain? i prefer a chain cleaner with degreaser.
What lube shold i use? not going there. whatever you normally use.
Can i leave the bike out in the sun to dry? yes' date=' but keep an eye on it. you don't want it to go to moz like intern's did.
this is going to open that can of worms again. my take in bold?
holy roller2010-02-11 00:06:09
How shold I maintain my MTB after a particularly muddy ride? Like Holy says. Hose it down first.
Can i use a high pressure hose? Like Holy says
Are there areas i should stay away from with the hose pipe? Like Holy says
What should i use to degrease/clean the chain?Like Holy says
What lube shold i use? Ask LBS. Some types are better for certain riding conditions
Can i leave the bike out in the sun to dry?It's better to dry it with a towel or something. Especially the chain.
After all of this, relube the chain and all the pivot points(rd, fd etc.)
Make sure you keep oil/lube away from the disk brake pads.
I like to also ride the bike for about 5mins. This ensures that the lube reaches all the contact points and further dries the bike.
