Hi there.
Random question: Anyone know if its posible to connect Xbox360 to laptop and play xbox live ?
Laptop connected to wireless network - very good connection.
Anyone up to par with Xbox live connections and subscriptions ?
Thanx
Yep astana you can, I have done it, but what speed is the wireless ? the normal 54mbps is too slow for FPS games.
I run a plug that send the signal from the router over the mains of the house to another plug that I connect to a hub and then to xbox etc. 85mbps, ok but still a very very very slight bit of lag playing locally, but mostly wont notice it.
with the laptop you must connect a lan cable between it and the xbox and then share the connection on the laptop, check the xbox has a static IP adress you allso need to open ports on the router etc, all the info on the site link.
