kori Posted April 5, 2010 Share attached is a pic of a cane creek headset on a felt f3.can someone help with a few easy steps to remove.thanks Link to comment Share on other sites More sharing options...
turtlek Posted April 5, 2010 Share Kori There should be a 4mm allenkey at the bottom of that hole tturn it oppostie to what you would normally loosen a bolt and it should come out with a little bit of friction be carefull not to strip the bolt because it is soft aluminium and it strips quite easily Link to comment Share on other sites More sharing options...
kori Posted April 5, 2010 Share how far down must the allenkey go? Link to comment Share on other sites More sharing options...
Register a new accountSign in
