American Classic MTB 26 Disc - Advice on going tubeless
I have a set of 2008 American Classic MTB 26 Disc 350 rims (non-tubeless) and would like to if anybody have done a tubeless conversion on these rims? I am planning to purchase the Continental Race King 2.2 Tubeless tires.
Pic of the rims below:
Hope someone can help?
No Problem currently running same wheels with stans conversion and Mavic Crossmark lust ust 2.1. No leaks.You will need a high presssure pump as hand and foot pump don't work when absolutely flat.
Cool!
Did you use the Stans rim strip, Stans rim tape or ghetto strip (BMX tube)?
Cool!
The stans rim strip and liquid.Good luck you won't be sorry.
I have the same setup as above. You will not be sorry. Changed my MTB cycling for the best. Run back at 2 bar and front at 1.8/1.9. Use foot pump to inflate.
There is an alternative. Instead of the stans strip, buy the tape at your hardware store and two joes/stans tubeless valves from your lbs.
Seal your rims with the tape, use 2 layers that overlap at the center, or 3 layers if you have wide rims.
Pierce the tape with a pen and stick the valves through it.
Use stans sealant, tubeless tyres and a strong compressor and they seat easily.
Thanks Guys!
PhilipV, do you cover the whole inside of the rim with the tape with the 3 layers (or do you leave a few millimetres uncovered)?
