Remote Lock-out - can it be added later?
Hello All,
Why google, if you Hubbers are funnier?
Can one add a remote lock-out to a 2008 F80 RLC Fox Fork, after purchase?
I seem to recall reading somewhere that you can buy a seperate unit for certain Roxshock's -- but was wondering about the Fox?
Any thoughts?
Fanks! :D
Had a similar question about installing a remote lockout on the rear shock, because I can understand the energy lost while climbing and you are bobbing around, but
when do you lock out a front shock - I have never actually seen the need to do this (ok I am used to stiff roadie forks so anything that absorbs a bit of shock is heaven and I dont want to switch it off!)
...when do you lock out a front shock - I have never actually seen the need to do this (ok I am used to stiff roadie forks so anything that absorbs a bit of shock is heaven and I dont want to switch it off!)
Tankman - each to their own, I guess?? As for me - my fork is almost always locked out, since I've set it up in such a manner that it still reacts to everything but the gnarly stuff...
Which means that when I need to unlock it - it's usually as I've started a hairy descent, and I only remember to do it when I've already begun the run :rolleyes: ...
I've had a few close shaves, purely because I'm leaning forward, around the bars, trying to dial my lock-out open, without actually concentrating on the pure evil that is rapidly unfolding under my front wheel :D
Having said all of this, it doesn't happen nearly enough to justify the expense (presumably?) of installing a remote lock-out - and the weird part of me, enjoys those moments of fear! So I guess I'm just asking really, without necessarily thinking of doing it :P
Rod AFAIK kits are available, but they are not normally as simple as remote lever, but also internals that have to be installed. As far as the rear shock goes I remember someone posting comments about Fox launching a full lock out retro fit kit for Rp23's at Interbike a few weeks ago, for those riders who feel the Pro Pedal lever does not make it stiff enough. M3CW.
:thumbup:
