Hi all
Can anyone please answer my question:
How can I quickly identify the 2011 Ultegra components? Is there any significant visual difference?
Reason I am asking is because I am busy buying a new bike and the shop says it is a 2011 bike but I have seen that bike standing there last year. Maybe they put on 2011 parts.
Thanks Mampara!
One other thing I am 1.85m, what size would you suggest? The shop has a 54cm (Medium frame) if I remember correctly and says it should be right because it is like a compact frame design or something like that.
Thanks Mampara!
A 54 compact frame is big. I am 1.88 and ride a 52 (M) compact which I had to "shorten" with a 90mm stem. Before that I was on a 56 regular shape frame. Every manufacturer's sizing is different.
Thanks Mampara!
Best thing to do is look at the manufactures website and their recommendation for what size you should ride.
The search the web for bike meansurements and see what your recommended top tube should be...then look at the geometry and get the one with the correct TT.
