I have just bought some gear cable and now when I get back home I see it has a plastic sheath inner, is this right? My old cable does not have this. It says Shimano SLR on the cable.
That is right... Aids in reducing friction and keeping the cable squeaky clean. Just be sure to "open" it up again with a sharp object after you've cut it prior to inserting the cable..
Thanks, I have put it all together, now when you use the barrel adjuster on the shifters the whole cable wants to turn as well, any tips on sorting that out so I can make some adjustments?
