hi all, i have made a monumental mistake, i striped my frame to sand and respray, as it is a carbon frame the cable tensioner's at least thats what i hope they are called) are not part of the frame in the same way they are on an alu frame, hence to get a proper spray done i drilled the pop rivets off and sprayed then re-attached, problem comes in where i have misplaced, and for love nor money i cant figure how or where, the front de-railer one. this as i am sure you can imagine presents a problem. does any one know where i can buy a replacement or perhaps have one from an old frame or something i can buy/ steal etc.
i honestly dont know what else to do or try.
thanks in advance.
Call your LBS, they should be able to hook you up if they are so inclined. (try to go for a more service orientated shop rather than one of the big corporate shops)
