Does anybody know of someone that does steel frame brazing?
I have a steel frame with a back stay that pulled out from the lug (opposite end from rear derailleur). Hence, it is a simple job for someone that knows how to work on steel frames. Preferably in Pretoria/JHB area.
Only guy I know who works on bikes specifically and might be able to help is Nat from Crosstown Cycls in CT?
I say might though since he moved here from Germany a couple months ago and I'm not sure if he's started building frames since the move.
Are you in a hurry to get this fixed? My acetylene stuff is in storage as I'm in-between houses.
Also, is the lug still clean or is there contamination inside there. If so, it isn't a simple job since the entire lug must come of for proper surface preparaton.
JB
I am not in a hurry -my second training bike.
I would appreciate it if you could help me -obviously after you assessed the scope of work you need to tell me what it would cost.<?:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
From what I can see, the lug is still clean of rust or any debris.
