Hi All,
Have been looking around at fixies and singlespeed bikes as I have recently purchased a track frame and want to build up a commuter bike.
Does anyone recognise the brakes in this pic (yes those are real bullhorns!)
http://www.fixiefien...bike650x493.jpg
In particular I like the levers.
Any ideas?
Many thanks,
W.
Edited by rckhpr29er
What bars are you going to be using, those almost look like a pair of TT break leavers ... almost
Thanks for the reply, I would like to put some bullhorn / pursuit bars. Still early on (in the build) but I like the bull horns with a single disc brake up front. I have seen guys making their own bullhorns using standard drop handlebars and will probably go that route as it is the cheapest!
There was a sale in the classifieds,a guy clearing his garage out.He had a set like these.
CRC also have these in stock
http://www.chainreac...?CategoryID=554
Yip those are the ones, the cane creek set look like a winner. Will keep a look out in the classifieds. Still doing a bit of saving and research but once I have an idea will post a question to the forum with my ideas.
Shot for the link!
You can get them locally as well from here:
http://www.planet-x-...ake-Levers.aspx
I take it the levers slide into the front of the bar, yes? Still a bit of a noob with these type of things. If that is the case then those are exactly what I am looking for.
Are they compatible with disk brakes?
Do I need to purchase the pair?
The track frame I bought does not have mounts on the stays for brakes so I am looking for a rigid fork with disk brake mounts.
