Ghost RT Lector 7700 vs. Giant Anthem x2
So i have decided that the Giant anthem is the better buy for me over the Giant Trance. But Enter the Ghost RT Lector 7700... which of the two would you say is the better buy. both are around R25k :( does anyone know the difference is weight as i cannot find this info anywhere!
or can you suggest other bikes that are in this category? i am after a bike hopefully no more than 12kgs!
RT Lector 7700 black
RT HM Carbon/Alloy MIMS SCL
Ritchey Comp 31.8 mm
Rock Shox Reba RL Solo PopLoc 100 mm Tapered
Ritchey Tapered
CG Carbon SL Flat 620 mm 31.8 mm
40/44/48/52/56 cm
CG Carbon SL 31.6 mm
Selle Italia SL
Shimano XT 10-Speed
Shimano XT
Shimano XT SL
Shimano XT
Shimano Pressfit BB
Shimano XT 42-32-24 incl. PressFit BB
Shimano XT Disc 180 mm
Schwalbe Rocket Ron 2.25
Alex SX 44 Disc
DT Swiss 1.8
Shimano XT
Shimano XT 10-Speed 11-34
FOX Float RP23 100 mm Boost Valve
100 mm
100 mm
Giant Anthem x2
Frame ALUXX SL-Grade Aluminum, 4" Maestro Suspension
Fork Fox F100 RL w/ 15QR Thru Axle and Tapered Steerer, 100mm Travel
Shock Fox Float RP2 Boostvalve
COMPONENTS
Handlebar Giant Connect SL, Low Rise 31.8
Stem Giant Connect SL, 28.6
Seatpost Giant Connect SL, 30.9
Saddle Fi'zi:k Tundra2 (Giant LTD Edition) w/ Manganese Rails
Pedals Not Included
DRIVETRAIN
Shifters Shimano Deore XT Dyna-Sys
Front Derailleur Shimano SLX
Rear Derailleur Shimano Deore XT Dyna-Sys, Shadow, Top Normal
Brakes Avid Elixir R
Brake Levers Avid Elixir R
Cassette Shimano SLX Dyna-Sys, 11x36, 10-Speed
Chain Shimano HG74
Crankset Shimano Deore XT Dyna-Sys, 24/32/42
Bottom Bracket Shimano Press Fit
WHEELS
Rims Giant P-XC2
Hubs [F] Giant Tracker w/15mm Axle, [R] DT 370, 32h
Spokes Sapim Race, 14/15g
Tires Maxxis Crossmark, 120 tpi, 26x2.1 Folding
ok sounding good. does the Anthem have "bob" when you pedal hard/ up hill? and is it just the Maestro suspension that giant use or the 4" travel or the entire combination?
I have had an anthem for 2 years now and the bike is fantastic. You do get a bit of bob when pedaling hard uphill if you dont lock the shock, but in reality i find the extra traction on steep loose surfaces more than makes up for any perceived loss of power through the shock. I only ever lock the rear shock if i am uphill on tar or a very hard smooth surface. Never weighed it but reckon around the 12kg mark.I have std 2009 anthem x1.
Great bike, but i cannot compare it to the others as it was my first proper mtb and the only one i know.
Enjoy making the decision.
