Hi all,
I have ridden MTB in the past for about 3 years but 2 years ago it got stolen... So I was thinking of getting a new one just to play around with for a bit of of road use :clap:
I was wondering if 10 speed is needed on a MTB or is 9 speed fine?
I have looked around a lot and this LOOKS like a bargain but I'm not sure...
Okay it's a Trek 4900 Disc hardtail 26" and not a 29er and with 10 SPEED SLX/DEORE groupo, the specs are:
- Front suspension
SR Suntour XCR-RL w/coil spring, preload, remote lockout, 100mm travel
- Wheels
Shimano RM66 center lock alloy hubs; Bontrager AT-850 disc 32-hole rims
- Shifters
Shimano Deore M591, 10 speed
- Front derailleur
Shimano Deore
- Rear derailleur
Shimano SLX M663 Shadow
- Crank
Shimano Deore Hollow
- Cassette
Shimano HG62-10 11-36, 10 speed
- Saddle
Bontrager Evoke 1
- Seatpost
Bontrager SSR, 31.6mm, 20mm offset
- Handlebar
Bontrager Low Riser OS, 31.8mm, 15mm rise, 9 degree sweep
- Stem
Bontrager Race Lite, 31.8mm
- Brakeset
Shimano M446 hydraulic disc brakes
I can get this bike, BRAND NEW for R7000 :unsure: it sounds like a bargain because it's got 10 speed on.
What do you guys think?
OR
Should I go 29er? I am 175cm tall I weigh 60kg's so I'm sure the 26" will do the job?
Thanks :thumbup:
Silverback is the best value for money bike you can get. For me the NB points are a Hollowtech II crank and don't settle for less than a Rock Shox Recon Air fork, I think Silverback has an option like that in the R7000 price class
Hoor by jou LBS of hulle nie miskien n 2010 silverback nabraska het.Dit is goeie waarde vir geld met n slx/xt groupset is dit goed gespec vir wat jy betaal.Hulle het nuut verkoop vir R8000.00 seker jy sal dit nou kan kry vir R7000.00 Bel cycle factory hulle stock baie silverbacks.
Good advice.
