Recommendations based on the following pls:
30km Tygerburg MTB ride on Sunday
Giant XTC HT
Maxxis Crossmark UST/Lust tubeless
I weigh around 71kgs
Many thanks Wink
ShortLegs2007-12-14 06:05:07
25 front is pushing it regardless of weather you ride tubeless or not, okay if you way 30 kg's its fine but otherwise a no no. You can run the tyre of the rim and damage the rim its self if you hit a rock at the wrong angle. I weigh a bit less than you and run both my karma's at 35 to 40 psi depending on the weather and terrain.
Guest colonel
It wont make a difference what you run considering you will be walking most of the time...........
Guest colonel
Now that was a 5yr olds answer if Ive ever seen it but you are correct cause Im not going to be at the race.
